주요 콘텐츠로 건너뛰기
GE 29875GE1 Microphone Replacement
필요한 것
  1. GE 29875GE1 Microphone Replacement, Remove the Form Pads: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Begin by looking at the bottom face of the device. Use the tweezers to remove the four foam pads which are covering four screws
  2. GE 29875GE1 Microphone Replacement, Remove the Screws: 2 단계, 이미지 1/1
    • Use the #2 philips screwdriver to remove the four screws from the bottoms of the device. These screw heads are sized 5.3mm or .209 in
  3. GE 29875GE1 Microphone Replacement, Opening the Device: 3 단계, 이미지 1/1
    • Remove the back casing panel by gently pulling back until you are able to reach the inside. gently pull the microphone out of its housing. This is only held in by friction so its easy to remove
  4. GE 29875GE1 Microphone Replacement, Locate Wires: 4 단계, 이미지 1/1
    • Locate the two wires attached to the microphone. The wires are attached to the back of the motherboard and are brown and black.
  5. GE 29875GE1 Microphone Replacement, Soldering: 5 단계, 이미지 1/1
    • Using the soldering station and soldering iron unsolder the two pins holding the microphone in place
  6. GE 29875GE1 Microphone Replacement, Replace Microphone: 6 단계, 이미지 1/1
    • Pull out the old microphone and discard it the correct way. Place the new microphone in the same spot the old one was in. Solder the new microphone to the correct pins
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mykaliah Best
회원 가입일: 10/31/14
184 평판
안내서 1개 작성함
UMass Dartmouth, Team 4-6, Miles Fall 2014 UMass Dartmouth, Team 4-6, Miles Fall 2014 회원
UMASSD-MILES-F14S4G6
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 317
