주요 콘텐츠로 건너뛰기
GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement
필요한 것
  1. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: 1 단계, 이미지 1/3 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: 1 단계, 이미지 2/3 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: 1 단계, 이미지 3/3
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery: 2 단계, 이미지 1/2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery: 2 단계, 이미지 2/2
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Screws: 3 단계, 이미지 1/2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Screws: 3 단계, 이미지 2/2
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, LCD Cover: 4 단계, 이미지 1/1
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Clock Radio: 5 단계, 이미지 1/2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Clock Radio: 5 단계, 이미지 2/2
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dominick Giguere
회원 가입일: 10/28/14
848 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 383
