주요 콘텐츠로 건너뛰기
GE Refrigerator Main Control Board Replacement
필요한 것
  1. GE Refrigerator Main Control Board Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. GE Refrigerator Main Control Board Replacement, Remove the main control board cover: 2 단계, 이미지 3개 중 1개 GE Refrigerator Main Control Board Replacement, Remove the main control board cover: 2 단계, 이미지 3개 중 2개 GE Refrigerator Main Control Board Replacement, Remove the main control board cover: 2 단계, 이미지 3개 중 3개
    • Use a 1/4" nut driver to remove the screws securing the main control board cover.
    • Remove the main control board cover.
  3. GE Refrigerator Main Control Board Replacement, Disconnect the main control board: 3 단계, 이미지 3개 중 1개 GE Refrigerator Main Control Board Replacement, Disconnect the main control board: 3 단계, 이미지 3개 중 2개 GE Refrigerator Main Control Board Replacement, Disconnect the main control board: 3 단계, 이미지 3개 중 3개
    • Note or take a photo of the position of all of the connectors
    • With your fingers, grasp each connector, squeeze any locking tabs, and pull all the connectors off the board.
  4. GE Refrigerator Main Control Board Replacement, Remove the main control board: 4 단계, 이미지 3개 중 1개 GE Refrigerator Main Control Board Replacement, Remove the main control board: 4 단계, 이미지 3개 중 2개 GE Refrigerator Main Control Board Replacement, Remove the main control board: 4 단계, 이미지 3개 중 3개
    • Using long nose pliers, squeeze the locking tabs on the mounting studs. While you do this, with your other hand pull the board gently outward so that the board won't slip back over a stud that has been released.
    • Lift the area of the board closest to the stud to free it from the mounting studs
    • Repeat this process of each mounting stud. until the board is free of each stud. Remove the board.
    • Try to work from one corner of the board down one side, then across. That will make it easier to maintain the gentle outward pressure and prevent the board from slipping back over the studs.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,555 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
1가이드 댓글
Control board 245D1888G002 R57 light blink all the time
Freddie Mckinney - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 53
전체 시간: 809
