주요 콘텐츠로 건너뛰기
GE Side By Side Refrigerator Ice Maker Replacement
필요한 것
  1. GE Side By Side Refrigerator Ice Maker Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. GE Side By Side Refrigerator Ice Maker Replacement, Remove ice bin: 2 단계, 이미지 3개 중 1개 GE Side By Side Refrigerator Ice Maker Replacement, Remove ice bin: 2 단계, 이미지 3개 중 2개 GE Side By Side Refrigerator Ice Maker Replacement, Remove ice bin: 2 단계, 이미지 3개 중 3개
    • Grasp the ice bin and lift it upward slightly.
    • Pull the bin out of the freezer compartment and remove it.
  3. GE Side By Side Refrigerator Ice Maker Replacement, Remove ice maker cover: 3 단계, 이미지 3개 중 1개 GE Side By Side Refrigerator Ice Maker Replacement, Remove ice maker cover: 3 단계, 이미지 3개 중 2개 GE Side By Side Refrigerator Ice Maker Replacement, Remove ice maker cover: 3 단계, 이미지 3개 중 3개
    • Lift the front edge of the cover 1cm (1/2") and pull the cover out of the freezer compartment.
  4. GE Side By Side Refrigerator Ice Maker Replacement, Unfasten ice maker: 4 단계, 이미지 1개 중 1개
    • Use a 1/4" nut driver to loosen or remove the two screws securing the ice maker in place.
  5. GE Side By Side Refrigerator Ice Maker Replacement, Reposition the ice maker: 5 단계, 이미지 3개 중 1개 GE Side By Side Refrigerator Ice Maker Replacement, Reposition the ice maker: 5 단계, 이미지 3개 중 2개 GE Side By Side Refrigerator Ice Maker Replacement, Reposition the ice maker: 5 단계, 이미지 3개 중 3개
    • Lift the icemaker upward to allow the mounting keyholes to slip over the screw heads.
  6. GE Side By Side Refrigerator Ice Maker Replacement: 6 단계, 이미지 2개 중 1개 GE Side By Side Refrigerator Ice Maker Replacement: 6 단계, 이미지 2개 중 2개
    • Reposition the ice maker to the lower right, below the auger motor.
    • You may be able to rest it on a lower shelf.
    • The ice maker is still connected to the electrical supply. Don't try to remove it yet.
  7. GE Side By Side Refrigerator Ice Maker Replacement, Disconnect ice maker: 7 단계, 이미지 3개 중 1개 GE Side By Side Refrigerator Ice Maker Replacement, Disconnect ice maker: 7 단계, 이미지 3개 중 2개 GE Side By Side Refrigerator Ice Maker Replacement, Disconnect ice maker: 7 단계, 이미지 3개 중 3개
    • Disconnect ice maker plug by loosening the retainer clips by lifting them if possible and then pulling the plug out of the socket. The socket is shown with the plug removed.
    • This may take some force. You can try lifting the retainer clips with a small flat head screwdriver, but access is difficult.
    • Remove the ice maker from the freezer compartment.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,555 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 25
지난 30일: 153
전체 시간: 1,687
