주요 콘텐츠로 건너뛰기
GE TrueTemp Oven Light Bulb Replacement
필요한 것
  1. GE TrueTemp Oven Light Bulb Replacement, Light Bulb: 1 단계, 이미지 1/1
    • Unplug the power cord from the wall outlet for safety purposes.
  2. GE TrueTemp Oven Light Bulb Replacement: 2 단계, 이미지 1/1
    • Open the oven door and locate the oven light placement (located on the back wall, in upper left corner for this specific model.)
  3. GE TrueTemp Oven Light Bulb Replacement: 3 단계, 이미지 1/1
    • Locate the metal strap holding the glass cover over the bulb.
  4. GE TrueTemp Oven Light Bulb Replacement: 4 단계, 이미지 1/1
    • Slide the strap to the side to free the glass casing.
  5. GE TrueTemp Oven Light Bulb Replacement: 5 단계, 이미지 1/1
    • View the light bulb without the glass case and ensure there is nothing else securing it to the oven.
    • Check to make sure there is no debris around the bulb and that the light bulb is ready to be removed.
  6. GE TrueTemp Oven Light Bulb Replacement: 6 단계, 이미지 1/1
    • Using a dry cloth or gloves, unscrew the light bulb by turning it in a counter clockwise motion.
  7. GE TrueTemp Oven Light Bulb Replacement: 7 단계, 이미지 1/2 GE TrueTemp Oven Light Bulb Replacement: 7 단계, 이미지 2/2
    • Screw in new light bulb in the clock wise direction.
  8. GE TrueTemp Oven Light Bulb Replacement: 8 단계, 이미지 1/1
    • Replace the glass cover over the bulb, but be sure to hold on to it tightly.
  9. GE TrueTemp Oven Light Bulb Replacement: 9 단계, 이미지 1/1
    • Secure the glass case to the oven with the metal strap by sliding it back over case until it fits tightly.
  10. GE TrueTemp Oven Light Bulb Replacement: 10 단계, 이미지 1/1
    • Plug the oven power cord back into power source.
  11. GE TrueTemp Oven Light Bulb Replacement: 11 단계, 이미지 1/1
    • Press the button for oven light to come on.
  12. GE TrueTemp Oven Light Bulb Replacement: 12 단계, 이미지 1/1
    • View light to ensure the replacement was successful.
결승점
Samantha Connell
회원 가입일: 01/21/18
214 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 회원
USFSM-STEWART-S18S1G1
15 회원들
안내서 26개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 39
30일 전: 140
전체 시간: 15,998
