주요 콘텐츠로 건너뛰기
GK61 Keyboard Keycap/Switch Replacement
필요한 것
  1. GK61 Keyboard Keycap/Switch Replacement, Keycap/Switches: 1 단계, 이미지 1/1
    • Unplug the keyboard.
    • When the keyboard lights are off, it indicates that the keyboard is turned off.
  2. GK61 Keyboard Keycap/Switch Replacement: 2 단계, 이미지 1/3 GK61 Keyboard Keycap/Switch Replacement: 2 단계, 이미지 2/3 GK61 Keyboard Keycap/Switch Replacement: 2 단계, 이미지 3/3
    • Use a keycap puller to remove the top and bottom of the keycaps from the keyboard.
    • When pulling the keycap, make sure to apply pressure until you hear a click sound from the keycap.
    • Remember when using a keycap puller, place it on a key in a vertical position.
  3. GK61 Keyboard Keycap/Switch Replacement: 3 단계, 이미지 1/1
    • After removing all the keycaps, put it in a bowl.
    • You can either use alcohol wipes or water to clean your keycaps.
  4. GK61 Keyboard Keycap/Switch Replacement: 4 단계, 이미지 1/1
    • Dry the keycaps on a rag or paper towel.
    • Remember to let your keycaps dry for about 5-10 minutes after cleaning.
  5. GK61 Keyboard Keycap/Switch Replacement: 5 단계, 이미지 1/1
    • Using a hand held vacuum cleaner remove any excess dust, hair, and oils.
    • Tilting your keyboard will also help for a deeper clean
    • If you cannot locate a hand held vacuum cleaner, a compressed air duster will also work.
  6. GK61 Keyboard Keycap/Switch Replacement: 6 단계, 이미지 1/3 GK61 Keyboard Keycap/Switch Replacement: 6 단계, 이미지 2/3 GK61 Keyboard Keycap/Switch Replacement: 6 단계, 이미지 3/3
    • Using a Q-Tip with rubbing alcohol, gently clean and rub the crevices around the plate of the keyboard.
    • Make sure not to pour rubbing alcohol onto your keyboard. Doing so may cause severe damage to the keyboard.
  7. GK61 Keyboard Keycap/Switch Replacement: 7 단계, 이미지 1/3 GK61 Keyboard Keycap/Switch Replacement: 7 단계, 이미지 2/3 GK61 Keyboard Keycap/Switch Replacement: 7 단계, 이미지 3/3
    • Using a switch puller, pull the keyboard switch from the top and bottom of the switch.
    • Remember to always pull straight up to fully remove the switch.
  8. GK61 Keyboard Keycap/Switch Replacement: 8 단계, 이미지 1/2 GK61 Keyboard Keycap/Switch Replacement: 8 단계, 이미지 2/2
    • Grab a replacement switch to replace the broken switch.
    • Push the switch straight down into the socket of the switch.
    • To avoid any damages, make sure to always push straight down and not in any other direction.
  9. GK61 Keyboard Keycap/Switch Replacement: 9 단계, 이미지 1/3 GK61 Keyboard Keycap/Switch Replacement: 9 단계, 이미지 2/3 GK61 Keyboard Keycap/Switch Replacement: 9 단계, 이미지 3/3
    • After drying the keycaps, put the keycaps back into their sockets.
    • Align the keycap with the socket of the switch and push straight down with a bit of pressure.
    • When pushing straight down, you will hear a click sound that will indicate that the keycap has been placed.
결론
Alexander Truong
회원 가입일: 05/05/21
169 평판
안내서 1개 작성함
York University, Team S1-G28, O'Regan Summer 2021 York University, Team S1-G28, O'Regan Summer 2021 회원
YORK-O'REGAN-SU21S1G28
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 39
전체 시간: 1,536
