주요 콘텐츠로 건너뛰기
GM Key Fob Plastic Housing Replacement
필요한 것
  1. GM Key Fob  Plastic Housing Replacement, Key Fob Plastic Housing: 1 단계, 이미지 1/1
    • Pry apart the key ring to remove it from the old housing.
  2. GM Key Fob  Plastic Housing Replacement: 2 단계, 이미지 1/3 GM Key Fob  Plastic Housing Replacement: 2 단계, 이미지 2/3 GM Key Fob  Plastic Housing Replacement: 2 단계, 이미지 3/3
    • Once you have removed the key ring, use it to open the housing by wedging it into the groove, as pictured.
  3. GM Key Fob  Plastic Housing Replacement: 3 단계, 이미지 1/2 GM Key Fob  Plastic Housing Replacement: 3 단계, 이미지 2/2
    • Remove the electrical board and rubber key pad from the old housing.
  4. GM Key Fob  Plastic Housing Replacement: 4 단계, 이미지 1/2 GM Key Fob  Plastic Housing Replacement: 4 단계, 이미지 2/2
    • Remove the electrical board from the rubber key pad.
  5. GM Key Fob  Plastic Housing Replacement: 5 단계, 이미지 1/2 GM Key Fob  Plastic Housing Replacement: 5 단계, 이미지 2/2
    • If necessary, remove the battery from the electrical board and replace it.
  6. GM Key Fob  Plastic Housing Replacement: 6 단계, 이미지 1/1
    • After Opening the new Key Fob package, select the correct housing as more than one model is included.
결론
To reassemble your device, simply follow these disassembly instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Megan Hayden
회원 가입일: 10/06/16
136 평판
안내서 1개 작성함
University of Memphis, Team 4-3, Baddour Fall 2016 University of Memphis, Team 4-3, Baddour Fall 2016 회원
UM-BADDOUR-F16S4G3
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 49
전체 시간: 2,502
