주요 콘텐츠로 건너뛰기
GOTRAX GMAX Ultra Brake Caliper Replacement
필요한 것
  1. GOTRAX GMAX Ultra Brake Caliper Replacement, Brake Caliper: 1 단계, 이미지 1/2 GOTRAX GMAX Ultra Brake Caliper Replacement, Brake Caliper: 1 단계, 이미지 2/2
    • Use the 5mm hex key to remove the 16mm screw holding the brake cable in place.
    • This will release the brake cable and metal clamp.
  2. GOTRAX GMAX Ultra Brake Caliper Replacement: 2 단계, 이미지 1/1
    • Next, use the 4 mm Hex key to remove the 14 mm screw on the side of the caliper that holds the housing to the brake pads.
    • As soon as the screw is loosened, a spring will release the tension of the caliper.
  3. GOTRAX GMAX Ultra Brake Caliper Replacement: 3 단계, 이미지 1/2 GOTRAX GMAX Ultra Brake Caliper Replacement: 3 단계, 이미지 2/2
    • Use the 4 mm Hex key to remove two 22 mm screws that hold the caliper to the scooter body.
    • Carefully remove these to avoid scratching the wheel cover with the hex key.
  4. GOTRAX GMAX Ultra Brake Caliper Replacement: 4 단계, 이미지 1/1
    • With the two screws removed, the caliper is now free from the scooter.
    • Loosen the screw and washer that holds the brake cable in place.
  5. GOTRAX GMAX Ultra Brake Caliper Replacement: 5 단계, 이미지 1/2 GOTRAX GMAX Ultra Brake Caliper Replacement: 5 단계, 이미지 2/2
    • This screw and washer stays on the scooter so it only needs to be loosened enough to free the cable.
    • No tools are required to loosen this, but you can always use something like pliers if it was screwed too tight.
  6. GOTRAX GMAX Ultra Brake Caliper Replacement: 6 단계, 이미지 1/1
    • Remove the brake caliper.
결론
To reassemble your device, simply follow these instructions in reverse order. You may have to adjust the caliper and brake cable in order for the disc to spin smoothly.
다른 한 분이 해당 안내서를 완성하였습니다.
Jeremy Goldberg
회원 가입일: 01/11/22
133 평판
안내서 1개 작성함
York University, Team R-11, Melo-Thaiss Winter 2022 York University, Team R-11, Melo-Thaiss Winter 2022 회원
YORK-MELO-THAISS-W22SRG11
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 39
30일 전: 126
전체 시간: 1,578
