주요 콘텐츠로 건너뛰기
GP Percussion DP778TN Double Bass Pedal Assembly Technique
필요한 것
  1. GP Percussion DP778TN Double Bass Pedal Assembly Technique, GP Percussion DP778TN Double Bass Pedal Assembly Technique: 1 단계, 이미지 1/1
    • Lay everything out
  2. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 2 단계, 이미지 1/2 GP Percussion DP778TN Double Bass Pedal Assembly Technique: 2 단계, 이미지 2/2
    • Remove the drum key and Allen wrenches from the right side of the primary pedal.
  3. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 3 단계, 이미지 1/2 GP Percussion DP778TN Double Bass Pedal Assembly Technique: 3 단계, 이미지 2/2
    • Slide the ends of the long black connector onto the sides of the pedals.
    • Both sides of the connection are shaped like a half-circle, so they can only connect in the proper orientation.
    • Ensure all the screws on the connector are pointing up. To do so, you will need to "wind" the secondary pedal up manually before attaching the connector.
  4. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 4 단계, 이미지 1/2 GP Percussion DP778TN Double Bass Pedal Assembly Technique: 4 단계, 이미지 2/2
    • Insert the beaters into the primary pedal.
    • You can choose to use either side of the beaters - just be consistent!
  5. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 5 단계, 이미지 1/3 GP Percussion DP778TN Double Bass Pedal Assembly Technique: 5 단계, 이미지 2/3 GP Percussion DP778TN Double Bass Pedal Assembly Technique: 5 단계, 이미지 3/3
    • Arrange the pedals in the drumkit. The primary pedal should be centered on the kick drum, while the secondary pedal should be wherever comfortable.
    • If necessary use the drum key to adjust the height of the beaters to be vertically centered on the kick drum.
    • Now tighten everything down!
  6. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 6 단계, 이미지 1/1
    • Tighten and loosen the nuts on the bottom of the springs until both pedals have an even, comfortable tension.
  7. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 7 단계, 이미지 1/2 GP Percussion DP778TN Double Bass Pedal Assembly Technique: 7 단계, 이미지 2/2
    • Replace the tools in the pedal for safe-keeping.
    • Bag the extra parts in case you want to convert your double-bass pedal into two singles.
  8. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 8 단계, 이미지 1/1
    • Pound out some sick beats!
결승점
다른 6명이 해당 안내서를 완성하였습니다.
James Pearson Hughes
회원 가입일: 05/27/10
650 평판
안내서 1개 작성함
eXifiters eXifiters 회원
Community
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Nice to see some double bass enthusiasts on here! I am in the process of building an electronic midi drumset from piezos, some old stationary cardio equipment and an alesis dm5. The tooling, oh the tooling. Taps and dies, welding, now i need a lathe to make a double bass pedal from scratch... Www.gpsn.uspto.gov is a great resource for technical info and also creepy government technology. Ill post when i can. Peace
Scott Haddox - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 21
전체 시간: 2,774
