이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Slide the ends of the long black connector onto the sides of the pedals.
Both sides of the connection are shaped like a half-circle, so they can only connect in the proper orientation.
Ensure all the screws on the connector are pointing up. To do so, you will need to "wind" the secondary pedal up manually before attaching the connector.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
Nice to see some double bass enthusiasts on here! I am in the process of building an electronic midi drumset from piezos, some old stationary cardio equipment and an alesis dm5. The tooling, oh the tooling. Taps and dies, welding, now i need a lathe to make a double bass pedal from scratch... Www.gpsn.uspto.gov is a great resource for technical info and also creepy government technology. Ill post when i can. Peace
