주요 콘텐츠로 건너뛰기
GPU Replacement
필요한 것
  1. GPU Replacement, Graphics Processing Unit: 1 단계, 이미지 1/1
    • Establish a clean work space.
  2. GPU Replacement: 2 단계, 이미지 1/3 GPU Replacement: 2 단계, 이미지 2/3 GPU Replacement: 2 단계, 이미지 3/3
    • Turn the desktop's power supply off.
    • Unplug the desktop from all power sources.
  3. GPU Replacement: 3 단계, 이미지 1/2 GPU Replacement: 3 단계, 이미지 2/2
    • Remove the screws on the side of the case.
    • Screw types may vary by desktop case.
    • These screws hold the side panel, which promotes airflow inside the desktop. Do not misplace them.
  4. GPU Replacement: 4 단계, 이미지 1/2 GPU Replacement: 4 단계, 이미지 2/2
    • Gently remove the side panel by pulling it away from the case.
  5. GPU Replacement: 5 단계, 이미지 1/1
    • Place the desktop horizontally, so the motherboard is facing up.
  6. GPU Replacement: 6 단계, 이미지 1/3 GPU Replacement: 6 단계, 이미지 2/3 GPU Replacement: 6 단계, 이미지 3/3
    • Disconnect the 8-pin PCI-E cable from the GPU.
  7. GPU Replacement: 7 단계, 이미지 1/2 GPU Replacement: 7 단계, 이미지 2/2
    • Remove the UTS 6-32 screws on the side of the desktop using a Phillips #0 or a flathead screwdriver.
    • These screws hold the GPU in place. Do not misplace them.
  8. GPU Replacement: 8 단계, 이미지 1/2 GPU Replacement: 8 단계, 이미지 2/2
    • Gently press down on the right side of the PCI-E tab until there is a click.
    • The click signifies the GPU has been released.
  9. GPU Replacement: 9 단계, 이미지 1/1
    • Gently pull the GPU out of the PCI-E slot.
  10. GPU Replacement: 10 단계, 이미지 1/3 GPU Replacement: 10 단계, 이미지 2/3 GPU Replacement: 10 단계, 이미지 3/3
    • Line up the pins of the new GPU with the empty PCI-E slot.
    • Gently push the new GPU into the PCI-E slot until the tab clicks.
  11. GPU Replacement: 11 단계, 이미지 1/3 GPU Replacement: 11 단계, 이미지 2/3 GPU Replacement: 11 단계, 이미지 3/3
    • Gently connect the 8-pin PCI-E cable from the power supply to the new GPU.
  12. GPU Replacement: 12 단계, 이미지 1/2 GPU Replacement: 12 단계, 이미지 2/2
    • Screw the UTS 6-32 screws which hold the GPU in place back in using a Phillips #0 screwdriver.
  13. GPU Replacement: 13 단계, 이미지 1/1
    • Gently place the side panel back on the case.
  14. GPU Replacement: 14 단계, 이미지 1/3 GPU Replacement: 14 단계, 이미지 2/3 GPU Replacement: 14 단계, 이미지 3/3
    • Screw in the side panel screws.
  15. GPU Replacement: 15 단계, 이미지 1/3 GPU Replacement: 15 단계, 이미지 2/3 GPU Replacement: 15 단계, 이미지 3/3
    • Plug the desktop back into a power source.
    • Turn the desktop's power supply on.
    • If the fans on the bottom of the GPU are not spinning once the desktop is on, retry this process. Or begin troubleshooting for a defective GPU.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Mason Price
회원 가입일: 10/25/22
295 평판
안내서 1개 작성함
CSU Los Angeles, Team 2-16, Briggs Fall 2022 CSU Los Angeles, Team 2-16, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S2G16
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 34
전체 시간: 1,164
