주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Galaxy A71 FPC Repair
필요한 것
동영상 개요
  1. Galaxy A71 FPC Repair, Connect the charger: 1 단계, 이미지 2개 중 1개 Galaxy A71 FPC Repair, Connect the charger: 1 단계, 이미지 2개 중 2개
    • Initial problem: Samsung Galaxy A71 does not charge.
    • Connect the charger and press the phone as shown in the second image.
  2. Galaxy A71 FPC Repair, Back cover removal: 2 단계, 이미지 3개 중 1개 Galaxy A71 FPC Repair, Back cover removal: 2 단계, 이미지 3개 중 2개 Galaxy A71 FPC Repair, Back cover removal: 2 단계, 이미지 3개 중 3개
    • Warm the device to soften the adhesive.
    • Use plastic tools and isopropyl alcohol to separate the back cover.
  3. Galaxy A71 FPC Repair, Middle frame removal / SIM Tray removal: 3 단계, 이미지 3개 중 1개 Galaxy A71 FPC Repair, Middle frame removal / SIM Tray removal: 3 단계, 이미지 3개 중 2개 Galaxy A71 FPC Repair, Middle frame removal / SIM Tray removal: 3 단계, 이미지 3개 중 3개
    • Remove all silver Phillips screws.
    • Remove the SIM Tray.
    • Use a suitable plastic tool (opening pick, spudger,...) to remove the middle frame.
  4. Galaxy A71 FPC Repair: 4 단계, 이미지 2개 중 1개 Galaxy A71 FPC Repair: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery.
    • Connect the charger and measure the voltage at the two end pins. It should be ~5V.
    • If not, search for the problem at the charging board or the main flex cable.
  5. Galaxy A71 FPC Repair: 5 단계, 이미지 2개 중 1개 Galaxy A71 FPC Repair: 5 단계, 이미지 2개 중 2개
    • Remove the black tape stuck around the connector.
    • Use a soldering iron, flux and tin wire to resolder the first pin of the FPC connector.
    • If the connector is broken, it's better to replace it.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
196,154 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
331 회원들
안내서 1,458개를 작성함
1가이드 댓글
Good morning. My A71 screen is blinking on and off black screen. What can I do to fix it? Also when I'm attempting to type in any chat I have to press down really hard to get the letters on the screen? As my phone heats up it goes black,if I'm in a room that has AC units it remains on for a longer period of time.
KEMBA LEOUNG TAT - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 66
지난 30일: 321
전체 시간: 16,964
