주요 콘텐츠로 건너뛰기
Galaxy A71 FPC Repair
필요한 것
동영상 개요
  1. Galaxy A71 FPC Repair, Connect the charger: 1 단계, 이미지 1/2 Galaxy A71 FPC Repair, Connect the charger: 1 단계, 이미지 2/2
    • Samsung Galaxy A71 does not charge.
    • Connect the charger and press the phone as per the second image.
  2. Galaxy A71 FPC Repair, Back cover removal: 2 단계, 이미지 1/3 Galaxy A71 FPC Repair, Back cover removal: 2 단계, 이미지 2/3 Galaxy A71 FPC Repair, Back cover removal: 2 단계, 이미지 3/3
    • Warm the device to soften the adhesive.
    • Use plastic tools and isopropyl alcohol to separate the back cover.
  3. Galaxy A71 FPC Repair, Middle frame removal / SIM Tray removal: 3 단계, 이미지 1/3 Galaxy A71 FPC Repair, Middle frame removal / SIM Tray removal: 3 단계, 이미지 2/3 Galaxy A71 FPC Repair, Middle frame removal / SIM Tray removal: 3 단계, 이미지 3/3
    • Remove all silver Phillips screws.
    • Remove the SIM Tray.
    • Use a suitable plastic tool to remove the middle frame.
  4. Galaxy A71 FPC Repair: 4 단계, 이미지 1/2 Galaxy A71 FPC Repair: 4 단계, 이미지 2/2
    • Disconnect the battery.
    • Connect the charger and measure the voltage at the two end pins. It should be ~5V.
    • If not, search for the problem at the charging board or the main flex cable.
  5. Galaxy A71 FPC Repair: 5 단계, 이미지 1/2 Galaxy A71 FPC Repair: 5 단계, 이미지 2/2
    • Remove the black tape stuck around the connector.
    • Use a soldering iron, flux and tin wire to resolder the first pin of the FPC connector.
    • If the connector is broken, it's better to replace it.
결론
다른 10명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,534 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,490개 작성하였습니다
댓글 한 개
Good morning. My A71 screen is blinking on and off black screen. What can I do to fix it? Also when I'm attempting to type in any chat I have to press down really hard to get the letters on the screen? As my phone heats up it goes black,if I'm in a room that has AC units it remains on for a longer period of time.
KEMBA LEOUNG TAT - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 58
30일 전: 290
전체 시간: 10,682
