주요 콘텐츠로 건너뛰기
Galaxy Book3 360 13" SSD Replacement
필요한 것
  1. Galaxy Book3 360 13" SSD Replacement, Remove the Screws: 1 단계, 이미지 1개 중 1개
    • Flip the laptop over and remove each rubber shoe
    • Use a Philips screwdriver to care fully remove each screw
  2. Galaxy Book3 360 13" SSD Replacement, Remove the Case: 2 단계, 이미지 2개 중 1개 Galaxy Book3 360 13" SSD Replacement, Remove the Case: 2 단계, 이미지 2개 중 2개
    • After removing the screws carefully pry open the case starting on the top right hinge.
    • There is a clip in the center of the laptop , when the edges are completely removed lift carefully to unclip the center.
  3. Galaxy Book3 360 13" SSD Replacement, Replace the SSD: 3 단계, 이미지 1개 중 1개
    • Carefully remove the screw holding down the SSD.
    • Lift the SSD until it is at about a 10-degree angle and then slide it out of the socket.
    • Slide in your new SSD, and follow the previous steps in reverse.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dan
회원 가입일: 02/18/19
4,985 평판
안내서 9개를 작성함
5가이드 댓글
Are you sure for the second slot it is 2280 and not 2230?
Jeremy Asher - 답글
How can I be sure for my NP750QFG that it's 2280 and not 2230?
Any advice?
Jeremy Asher - 답글
Galaxy book 3 360 15.6" inch variant support Gen 3 NVMe 2280 type ssd like WD Black SN770
Biswajit Shial -
Mine is 15.6 size and it's for the second slot, the 13" I think didn't have a second slot.
How do I know i it's for 2230 or 2280?
Jeremy Asher - 답글
I opened my Book3 Pro 360 5G and the SSD is covered by a metal shield. How do I remove this shield to gain access to the SSD and slot?
Lloyd Franklin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 55
지난 30일: 319
전체 시간: 16,101
