소개
To replace the SSD you will need a Pry Tool and Phillips screw driver.
필요한 것
Flip the laptop over and remove each rubber shoe
Use a Philips screwdriver to care fully remove each screw
After removing the screws carefully pry open the case starting on the top right hinge.
There is a clip in the center of the laptop , when the edges are completely removed lift carefully to unclip the center.
Carefully remove the screw holding down the SSD.
Lift the SSD until it is at about a 10-degree angle and then slide it out of the socket.
Slide in your new SSD, and follow the previous steps in reverse.
다른 5명이 해당 안내서를 완성하였습니다.
