주요 콘텐츠로 건너뛰기
Galaxy J3 Prime LCD Screen Replacement
필요한 것
동영상 개요
    • Remove the back cover and battery.
    • Heat up the screen to loosen the adhesive.
    • You can use a iOpener or a hair drier, but make sure you don't get the phone too hot.
    • Put a spudger between the phone frame and the front display.
    • Remove the plastic bracket that will be visible when you pry up the screen.
    • Gently pull up on the LCD screen adhesive to remove the screen.
    • Remove the screws on the back of the phone frame that are holding the housing of the phone together.
    • Now that all of the screws have been removed, pull up the frame with a screwdriver or spudger.
    • Be gentle so you don't break anything.
    • Disconnect the metal flex cable from the charging port.
    • Remove the Motherboard from the housing.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Brian Brown
회원 가입일: 09/26/16
393 평판
안내서 1개를 작성함
3가이드 댓글
great guide, this really helped
anonymous 591 - 답글
thanks for your help, this has really helped
Marvinhenderson4@gmail.com - 답글
Best guide for a J3 out there professional and easy to follow
Keith Pobuta - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 7,262
