주요 콘텐츠로 건너뛰기
Galaxy Tab S 10.5 Camera Replacement
필요한 것
  1. Galaxy Tab S 10.5 Camera Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: 1 단계, 이미지 1/2 Galaxy Tab S 10.5 Camera Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: 1 단계, 이미지 2/2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Galaxy Tab S 10.5 Camera Replacement: 2 단계, 이미지 1/1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Galaxy Tab S 10.5 Camera Replacement: 3 단계, 이미지 1/1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Galaxy Tab S 10.5 Camera Replacement, Camera: 4 단계, 이미지 1/3 Galaxy Tab S 10.5 Camera Replacement, Camera: 4 단계, 이미지 2/3 Galaxy Tab S 10.5 Camera Replacement, Camera: 4 단계, 이미지 3/3
    • Use a spudger to disconnect the camera from the motherboard and then remove the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jordan Soto
회원 가입일: 08/26/15
3,276 평판
안내서 6개 작성하였습니다
USF Tampa, Team 3-2, Eyestone Fall 2015 USF Tampa, Team 3-2, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G2
3 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 2,569
