소개
How to remove the back panel from a Game Boy Advance.
필요한 것
동영상 개요
Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
Remove the six back panel screws using a Tri-wing Screwdriver.
Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
Remove the back panel by pulling away with one hand and the front secured in the other hand.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Seeing the GBA-SP guide, could information here be added so we know which mm triwing screws the regular GBA backpanel uses?
