주요 콘텐츠로 건너뛰기
Game Boy Advance Buttons Replacement
필요한 것
  1. Game Boy Advance Buttons Replacement, Remove the Battery Cover/Batteries: 1 단계, 이미지 1/3 Game Boy Advance Buttons Replacement, Remove the Battery Cover/Batteries: 1 단계, 이미지 2/3 Game Boy Advance Buttons Replacement, Remove the Battery Cover/Batteries: 1 단계, 이미지 3/3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Buttons Replacement, Unscrew the Back Panel: 2 단계, 이미지 1/2 Game Boy Advance Buttons Replacement, Unscrew the Back Panel: 2 단계, 이미지 2/2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Buttons Replacement, Remove the Back Panel: 3 단계, 이미지 1/1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance Buttons Replacement, Remove Triggers: 4 단계, 이미지 1/2 Game Boy Advance Buttons Replacement, Remove Triggers: 4 단계, 이미지 2/2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
    my side pannel on the right is a little loose how do i fix it
    Mark - 답글
  5. Game Boy Advance Buttons Replacement, Remove the On/Off Switch: 5 단계, 이미지 1/1
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  6. Game Boy Advance Buttons Replacement, Buttons and LCD Screen: 6 단계, 이미지 1/1
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
  7. Game Boy Advance Buttons Replacement: 7 단계, 이미지 1/2 Game Boy Advance Buttons Replacement: 7 단계, 이미지 2/2
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Handle with care! The ribbon connecting the circuit board to the LCD screen can easily be damaged and will require replacement if broken.
  8. Game Boy Advance Buttons Replacement, Buttons: 8 단계, 이미지 1/3 Game Boy Advance Buttons Replacement, Buttons: 8 단계, 이미지 2/3 Game Boy Advance Buttons Replacement, Buttons: 8 단계, 이미지 3/3
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
결승점
다른 14명이 해당 안내서를 완성하였습니다.
Ben
회원 가입일: 01/22/10
530 평판
안내서 1개 작성함
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010 회원
CPSU-MANESS-W10S16G29
5 회원들
안내서 61개 작성하였습니다
댓글 한 개
If you have buttons that don’t respond, you can also just clean the contacts (the round black ones and the gold ones on the board) with alcohol and a Q-tip. After that, I coated the contacts with some contact spray, also with Q-tip. All buttons are working again.
Simon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 118
30일 전: 412
전체 시간: 23,459
