주요 콘텐츠로 건너뛰기
Game Boy Advance Buttons and LCD Screen Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Game Boy Advance Buttons and LCD Screen Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Game Boy Advance Buttons and LCD Screen Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Game Boy Advance Buttons and LCD Screen Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
    • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
    • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
  2. Game Boy Advance Buttons and LCD Screen Replacement, Remove the batteries: 2 단계, 이미지 3개 중 1개 Game Boy Advance Buttons and LCD Screen Replacement, Remove the batteries: 2 단계, 이미지 3개 중 2개 Game Boy Advance Buttons and LCD Screen Replacement, Remove the batteries: 2 단계, 이미지 3개 중 3개
    • Remove the two AA batteries.
    • If the metal terminals are corroded, follow this guide to clean them.
    • When installing batteries, use the diagram in the battery well to properly orient them.
  3. Game Boy Advance Buttons and LCD Screen Replacement, Remove the back shell screws: 3 단계, 이미지 2개 중 1개 Game Boy Advance Buttons and LCD Screen Replacement, Remove the back shell screws: 3 단계, 이미지 2개 중 2개
    • Remove the seven screws securing the back shell:
    • Six 9.4 mm‑long tri‑point Y0 screws
    • One 8.5 mm‑long JIS 1 screw
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
  4. Game Boy Advance Buttons and LCD Screen Replacement, Remove the back shell: 4 단계, 이미지 2개 중 1개 Game Boy Advance Buttons and LCD Screen Replacement, Remove the back shell: 4 단계, 이미지 2개 중 2개
    • Lift the back shell straight up and remove it.
    • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
  5. Game Boy Advance Buttons and LCD Screen Replacement, Remove Triggers: 5 단계, 이미지 2개 중 1개 Game Boy Advance Buttons and LCD Screen Replacement, Remove Triggers: 5 단계, 이미지 2개 중 2개
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  6. Game Boy Advance Buttons and LCD Screen Replacement, Remove the On/Off Switch: 6 단계, 이미지 1개 중 1개
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  7. Game Boy Advance Buttons and LCD Screen Replacement, Buttons and LCD Screen: 7 단계, 이미지 1개 중 1개
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
  8. Game Boy Advance Buttons and LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Game Boy Advance Buttons and LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Handle with care! The ribbon connecting the circuit board to the LCD screen can easily be damaged and will require replacement if broken.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Aldo Corona
회원 가입일: 01/25/10
886 평판
안내서 8개를 작성함
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010 회원
CPSU-MANESS-W10S16G29
5 회원들
안내서 81개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 8,621
