소개
Use this repair guide when debris needs to be cleared from the On/Off switch or it needs to be replaced.
도구
부품
지정된 부품이 없습니다.
Remove left and right triggers by lifting and pulling them away from the system.
Do the same for side panels
Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
