주요 콘텐츠로 건너뛰기
Game Boy Cartridge Battery Replacement
필요한 것
  1. Game Boy Cartridge Battery Replacement, Identification: 1 단계, 이미지 1/3 Game Boy Cartridge Battery Replacement, Identification: 1 단계, 이미지 2/3 Game Boy Cartridge Battery Replacement, Identification: 1 단계, 이미지 3/3
    • The first step is to locate the problem. The Game Boy will give you a message such as this.
    • The battery you will need for this cartridge (an original game Boy game) is a CR2025 3V battery.
  2. Game Boy Cartridge Battery Replacement: 2 단계, 이미지 1/3 Game Boy Cartridge Battery Replacement: 2 단계, 이미지 2/3 Game Boy Cartridge Battery Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Get your soldering iron heated, gather your tools, tweezers, and a Steel 3.8mm Screwdriver Security Bit
  3. Game Boy Cartridge Battery Replacement: 3 단계, 이미지 1/3 Game Boy Cartridge Battery Replacement: 3 단계, 이미지 2/3 Game Boy Cartridge Battery Replacement: 3 단계, 이미지 3/3
    • On the back side of the cartridge is a priority security bit and you will have to remove it.
  4. Game Boy Cartridge Battery Replacement: 4 단계, 이미지 1/3 Game Boy Cartridge Battery Replacement: 4 단계, 이미지 2/3 Game Boy Cartridge Battery Replacement: 4 단계, 이미지 3/3
    • Next you will need to slide the front face of the cartridge down to expose the motherboard
    • Remove the board from the plastic housing and clamp it in a vice with alligator clips for stability
  5. Game Boy Cartridge Battery Replacement: 5 단계, 이미지 1/3 Game Boy Cartridge Battery Replacement: 5 단계, 이미지 2/3 Game Boy Cartridge Battery Replacement: 5 단계, 이미지 3/3
    • Use the soldering iron to gently heat the top tab while at the same time using the tweezers to pull the top tab away from the board
    • Then do the same to the bottom tab until the battery is free, be sure no to heat the board too much and only where it is soldered
    • Install the new battery in reverse order heating the solder first then setting the tabs on the hot solder, a little more solder may be needed to hold it in place, once it is cool check that the battery is secure
  6. Game Boy Cartridge Battery Replacement: 6 단계, 이미지 1/2 Game Boy Cartridge Battery Replacement: 6 단계, 이미지 2/2
    • The final step is to set the board back into the plastic housing slide the cover shut and tighten the screw
결론
다른 19명이 해당 안내서를 완성하였습니다.
Zane Hogue
회원 가입일: 07/14/14
739 평판
안내서 1개 작성함
댓글 6개
Do you know what battery type is needed for older games like Pokémon Green?
There are no telling marks and it's notably smaller than the battery used for others I've fixed like Crystal or Red. I want to be sure I'm using the right replacement.
jackson3jonathan - 답글
The older cartridges should use the CR2025 the gameboy advanced cartridges sometimes use the CR1616, I buy my batteries off of amazon with the soldering tabs on them
Zane Hogue -
When you change a Gameboy Cartridge battery, do you lose the currunt game save , THX
Ken Stock - 답글
Yes, anytime power is lost to the volatile memory the save is wiped.
Austin Fischer -
The purpose of the battery in the cartridge is to retain stored memory such as saved games so if you remove the battery for replacement or the battery dies it will delete the saved game. Sucks really hope this helps
Zane Hogue - 답글
댓글 쓰기
조회 통계:
24 시간 전: 24
7일 전: 197
30일 전: 951
전체 시간: 58,157
