소개
Is the outside shell of your Game Boy cracked, damaged, or you're just getting sick of your old housing? This guide outlines how to get down to the front housing so you can swap it out!
필요한 것
Locate the battery compartment on the back of the Game Boy Color.
Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
다른 17명이 해당 안내서를 완성하였습니다.
