주요 콘텐츠로 건너뛰기
Game Boy Color Front Housing Replacement
필요한 것
  1. Game Boy Color Front Housing Replacement, Battery: 1 단계, 이미지 1/2 Game Boy Color Front Housing Replacement, Battery: 1 단계, 이미지 2/2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Front Housing Replacement: 2 단계, 이미지 1/1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Front Housing Replacement, Back Housing: 3 단계, 이미지 1/1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Front Housing Replacement: 4 단계, 이미지 1/2 Game Boy Color Front Housing Replacement: 4 단계, 이미지 2/2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Front Housing Replacement, LCD Ribbon Cable: 5 단계, 이미지 1/1
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Front Housing Replacement: 6 단계, 이미지 1/1
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Front Housing Replacement, Motherboard: 7 단계, 이미지 1/2 Game Boy Color Front Housing Replacement, Motherboard: 7 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Game Boy Color Front Housing Replacement: 8 단계, 이미지 1/1
    • Gently lift the motherboard from the front housing.
  9. Game Boy Color Front Housing Replacement, Buttons: 9 단계, 이미지 1/1
    • Remove the rubber backing on each button grouping.
  10. Game Boy Color Front Housing Replacement: 10 단계, 이미지 1/1
    • Remove the original buttons from the housing.
  11. Game Boy Color Front Housing Replacement, LCD Display: 11 단계, 이미지 1/2 Game Boy Color Front Housing Replacement, LCD Display: 11 단계, 이미지 2/2
    • Gently pry and lift the LCD Display from the front panel.
    • Twisting the front casing may help gain more leverage.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Angela Yoeurng
회원 가입일: 01/18/13
1,665 평판
안내서 2개 작성하였습니다
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 회원
CPSU-REGAN-W13S19G47
4 회원들
안내서 61개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 22
30일 전: 87
전체 시간: 11,125
