주요 콘텐츠로 건너뛰기
Game Boy Color LCD Ribbon Cable Replacement
필요한 것
  1. Game Boy Color LCD Ribbon Cable Replacement, Battery: 1 단계, 이미지 1/2 Game Boy Color LCD Ribbon Cable Replacement, Battery: 1 단계, 이미지 2/2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color LCD Ribbon Cable Replacement: 2 단계, 이미지 1/1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color LCD Ribbon Cable Replacement, Back Housing: 3 단계, 이미지 1/1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
    I did this with a Y0 bit. It works if you are careful. I wouldn't recommend it on other consoles but for this tiny thing, it works.
    phnome - 답글
    The guide says a Y0 is needed. Is it a Y1 or Y0?
    Trav - 답글
  4. Game Boy Color LCD Ribbon Cable Replacement: 4 단계, 이미지 1/2 Game Boy Color LCD Ribbon Cable Replacement: 4 단계, 이미지 2/2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color LCD Ribbon Cable Replacement, LCD Ribbon Cable: 5 단계, 이미지 1/1
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color LCD Ribbon Cable Replacement: 6 단계, 이미지 1/1
    • Gently remove the ribbon cable from the port
결론
다른 11명이 해당 안내서를 완성하였습니다.
Nick Katsantones
회원 가입일: 01/18/13
946 평판
안내서 4개 작성하였습니다
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 회원
CPSU-REGAN-W13S19G47
4 회원들
안내서 56개 작성하였습니다
댓글 한 개
How many pins are in the ribbon?
jakebrown199 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 77
전체 시간: 8,333
