주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Fixing the common problem of lines/bars on the original Nintendo GameBoy
  1. Remove the back housing by removing the 6 Tri-Point or Philip screws. Note: The last 2 screws are in the battery compartment. Note: The last 2 screws are in the battery compartment.
    • Remove the back housing by removing the 6 Tri-Point or Philip screws.
    • Note: The last 2 screws are in the battery compartment.
  2. Carefully lift up the top half of the system. Be careful, there's a ribbon cable that connects the top and bottom half of the system. Remove the ribbon cable for the next step.
    • Carefully lift up the top half of the system. Be careful, there's a ribbon cable that connects the top and bottom half of the system.
    • Remove the ribbon cable for the next step.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Now there will be screws that mount the board to the front, carefully unscrew these. Now remove the board from the housing. Now put the batteries back into the compartment, so you can test the screen while you fix it.
    • Now there will be screws that mount the board to the front, carefully unscrew these.
    • Now remove the board from the housing.
    • Now put the batteries back into the compartment, so you can test the screen while you fix it.
    • Reconnect the the board to back housing with the ribbon cable.
  5. You're now going to turn the contrast ( the slider on the left) all the way up, and take your soldering iron and gently move it back and forth on the ribbon cable below the screen.
    • You're now going to turn the contrast ( the slider on the left) all the way up, and take your soldering iron and gently move it back and forth on the ribbon cable below the screen.
    • Make sure not to touch the screen itself.
    • Note: There may be a rubber strip covering the ribbon.
    • You will start to see the lines of pixels fade in and out, keep moving your iron back and forth until screen is completely black.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Mitchell
회원 가입일: 2016년 04월 03일
156 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 2,935
