주요 콘텐츠로 건너뛰기
Game Boy Headphone Jack Replacement
필요한 것
  1. Game Boy Headphone Jack Replacement, Batteries: 1 단계, 이미지 1/2 Game Boy Headphone Jack Replacement, Batteries: 1 단계, 이미지 2/2
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Headphone Jack Replacement: 2 단계, 이미지 1/3 Game Boy Headphone Jack Replacement: 2 단계, 이미지 2/3 Game Boy Headphone Jack Replacement: 2 단계, 이미지 3/3
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Headphone Jack Replacement: 3 단계, 이미지 1/2 Game Boy Headphone Jack Replacement: 3 단계, 이미지 2/2
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Game Boy Headphone Jack Replacement, Outer Case: 4 단계, 이미지 1/1
    • Remove the six Triwing screws from the back of the device.
  5. Game Boy Headphone Jack Replacement: 5 단계, 이미지 1/1
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Game Boy Headphone Jack Replacement: 6 단계, 이미지 1/1
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Game Boy Headphone Jack Replacement: 7 단계, 이미지 1/1
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
  8. Game Boy Headphone Jack Replacement, Headphone Jack: 8 단계, 이미지 1/2 Game Boy Headphone Jack Replacement, Headphone Jack: 8 단계, 이미지 2/2
    • The headphone jack is located on the bottom of the rear outer casing, near the battery compartment.
    • Use a Phillips #00 screwdriver to remove the two screws holding the headphone jack in place.
  9. Game Boy Headphone Jack Replacement: 9 단계, 이미지 1/2 Game Boy Headphone Jack Replacement: 9 단계, 이미지 2/2
    • Once the headphone jack is detached it will dangle by the wires attached to the main circuit board. Do not worry about the connections, they are solid and will not break.
    • Use a Phillips#00 screwdriver to remove the two screws that hold the main circuit board to the casing. This will allow access to the connection points of the headphone jack.
  10. Game Boy Headphone Jack Replacement: 10 단계, 이미지 1/2 Game Boy Headphone Jack Replacement: 10 단계, 이미지 2/2
    • Use a plastic opening tool to remove the main circuit board from the casing.
    • Once the main circuit board is removed, set aside the outer casing.
  11. Game Boy Headphone Jack Replacement: 11 단계, 이미지 1/3 Game Boy Headphone Jack Replacement: 11 단계, 이미지 2/3 Game Boy Headphone Jack Replacement: 11 단계, 이미지 3/3
    • Desolder the four wires connecting the headphone jack to the motherboard.
    • Desolder the four wires connected to the headphone jack
    • To learn more about soldering, check out iFixit's soldering technique guide.
    • Remove the headphone jack with tweezers.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Andrew Tramposch
회원 가입일: 06/24/10
2,225 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010 회원
CPSU-JOHANN-R10S3G2
3 회원들
안내서 34개 작성하였습니다
댓글 한 개
Hi, great work, but where could I find replacement to buy?
Thanks
fred fred - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 39
30일 전: 120
전체 시간: 18,504
