주요 콘텐츠로 건너뛰기
Game Boy Outer Case Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Game Boy Outer Case Replacement, Batteries: 1 단계, 이미지 1/2 Game Boy Outer Case Replacement, Batteries: 1 단계, 이미지 2/2
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Outer Case Replacement: 2 단계, 이미지 1/3 Game Boy Outer Case Replacement: 2 단계, 이미지 2/3 Game Boy Outer Case Replacement: 2 단계, 이미지 3/3
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Outer Case Replacement: 3 단계, 이미지 1/2 Game Boy Outer Case Replacement: 3 단계, 이미지 2/2
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Game Boy Outer Case Replacement, Outer Case: 4 단계, 이미지 1/1
    • Remove the six Triwing screws from the back of the device.
  5. Game Boy Outer Case Replacement: 5 단계, 이미지 1/1
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Game Boy Outer Case Replacement: 6 단계, 이미지 1/1
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Game Boy Outer Case Replacement: 7 단계, 이미지 1/1
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Andrew Tramposch
회원 가입일: 06/24/10
2,243 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010 회원
CPSU-JOHANN-R10S3G2
3 회원들
안내서 34개 작성하였습니다
댓글 2개
U need a tri-wing screwdriver not a Philips #00
radiofreeroyaloak - 답글
It is a Philips if gb was made after 1998 or so.
Sam - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 15,686
