소개
Removing the back cover is an essential step that must be carried out before removing or replacing other parts.
필요한 것
Place the Game Boy Pocket face-down on a clean, flat surface.
Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
다른 한 분이 해당 안내서를 완성하였습니다.
