주요 콘텐츠로 건너뛰기
Game Boy Pocket LCD Screen Replacement
필요한 것
  1. Game Boy Pocket LCD Screen Replacement, Remove the external screws: 1 단계, 이미지 3개 중 1개 Game Boy Pocket LCD Screen Replacement, Remove the external screws: 1 단계, 이미지 3개 중 2개 Game Boy Pocket LCD Screen Replacement, Remove the external screws: 1 단계, 이미지 3개 중 3개
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Remove batteries from battery compartment.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket LCD Screen Replacement, Open the device: 2 단계, 이미지 3개 중 1개 Game Boy Pocket LCD Screen Replacement, Open the device: 2 단계, 이미지 3개 중 2개 Game Boy Pocket LCD Screen Replacement, Open the device: 2 단계, 이미지 3개 중 3개
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket LCD Screen Replacement, Remove the motherboard screws: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
  4. Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: 4 단계, 이미지 3개 중 1개 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: 4 단계, 이미지 3개 중 2개 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: 5 단계, 이미지 2개 중 1개 Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: 5 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket LCD Screen Replacement, Remove the motherboard: 6 단계, 이미지 3개 중 1개 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: 6 단계, 이미지 3개 중 2개 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: 6 단계, 이미지 3개 중 3개
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
    • Set the motherboard aside. You will need it to reassemble the device.
  7. Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: 7 단계, 이미지 3개 중 1개 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: 7 단계, 이미지 3개 중 2개 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: 7 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to lift the LCD screen away from the front cover.
    • Use your fingers to remove the LCD screen.
결론
다른 19명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Adriana Rahrig
회원 가입일: 10/07/14
1,637 평판
안내서 5개를 작성함
USF Tampa, Team 1-1, Leahy Fall 2014 USF Tampa, Team 1-1, Leahy Fall 2014 회원
USFT-LEAHY-F14S1G1
4 회원들
안내서 19개를 작성함
3가이드 댓글
please can anyone give me a website that sells replacemtn screens for the Gameboy pocket?
help please - 답글
There's no website that sells replacement screens the only way to get one is to order another Gameboy off of eBay and take out the screen
Isaac fraser -
I get mine from Handheld Legend. They have all the Gameboy parts you could ever want.
Chris Pavlik -
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 75
지난 30일: 371
전체 시간: 31,361
