주요 콘텐츠로 건너뛰기
Game Boy Pocket Motherboard Replacement
필요한 것
  1. Game Boy Pocket Motherboard Replacement, Back Cover: 1 단계, 이미지 1/3 Game Boy Pocket Motherboard Replacement, Back Cover: 1 단계, 이미지 2/3 Game Boy Pocket Motherboard Replacement, Back Cover: 1 단계, 이미지 3/3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Motherboard Replacement: 2 단계, 이미지 1/3 Game Boy Pocket Motherboard Replacement: 2 단계, 이미지 2/3 Game Boy Pocket Motherboard Replacement: 2 단계, 이미지 3/3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
  4. Game Boy Pocket Motherboard Replacement: 4 단계, 이미지 1/3 Game Boy Pocket Motherboard Replacement: 4 단계, 이미지 2/3 Game Boy Pocket Motherboard Replacement: 4 단계, 이미지 3/3
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket Motherboard Replacement: 5 단계, 이미지 1/2 Game Boy Pocket Motherboard Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket Motherboard Replacement: 6 단계, 이미지 1/2 Game Boy Pocket Motherboard Replacement: 6 단계, 이미지 2/2
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Adriana Rahrig
회원 가입일: 10/07/14
1,523 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-1, Leahy Fall 2014 USF Tampa, Team 1-1, Leahy Fall 2014 회원
USFT-LEAHY-F14S1G1
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 71
전체 시간: 5,121
