주요 콘텐츠로 건너뛰기
Game Boy Pocket Power Button Replacement
필요한 것
  1. Game Boy Pocket Power Button Replacement, Remove the external screws: 1 단계, 이미지 1/3 Game Boy Pocket Power Button Replacement, Remove the external screws: 1 단계, 이미지 2/3 Game Boy Pocket Power Button Replacement, Remove the external screws: 1 단계, 이미지 3/3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Power Button Replacement, Open the device: 2 단계, 이미지 1/3 Game Boy Pocket Power Button Replacement, Open the device: 2 단계, 이미지 2/3 Game Boy Pocket Power Button Replacement, Open the device: 2 단계, 이미지 3/3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket Power Button Replacement, Remove the power button: 3 단계, 이미지 1/3 Game Boy Pocket Power Button Replacement, Remove the power button: 3 단계, 이미지 2/3 Game Boy Pocket Power Button Replacement, Remove the power button: 3 단계, 이미지 3/3
    • Use your fingers to remove the grey power button to the right of the ribbon cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adriana Rahrig
회원 가입일: 10/07/14
1,523 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-1, Leahy Fall 2014 USF Tampa, Team 1-1, Leahy Fall 2014 회원
USFT-LEAHY-F14S1G1
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 36
전체 시간: 3,684
