이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
Gently separate the device's front casing from the back casing after you remove the screws.
Slide the front side of the casing down to expose the ribbon cable connector.
Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
Separate the front and back casings.
Remove the ten screws that connect the circuit board to the outer case.
Remove the circuit board from the outer case using a plastic opening tool.
Disengage the the three plastic clips that secure the screen to the circuit board.
Flip the circuit board over revealing the device screen.
Remove the two screws connecting the screen and the circuit board.
Follow the video instructions to desolder the display connectors and replace your screen.
다른 45명이 해당 안내서를 완성하였습니다.
댓글 11개
What kind of lcd screen or where can I find one that isn't off of another dmg-01 gameboy?
Floyd Odom - 답글
I was wondering the same. Maybe ebay or Amazon.
What about the new display? Where to get it?
No spare part necessary should be replaced with a link where to buy a new one.
You can’t buy a new replacement screen unfortunately. Not only is it very difficult to remove the screen, it’s impossible to buy a replacement. They’d be better showing us how to fix a screen. There’s plenty of videos on YT showing how to fix blank vertical line but hardly any on how to fix horizontal lines, and the ones that do don’t work very well.
Where do I buy a replacement screen for a 1989 game boy?
