주요 콘텐츠로 건너뛰기
Game Boy Speaker Replacement
필요한 것
동영상 개요
  1. Game Boy Speaker Replacement, Batteries: 1 단계, 이미지 1/2 Game Boy Speaker Replacement, Batteries: 1 단계, 이미지 2/2
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Speaker Replacement: 2 단계, 이미지 1/3 Game Boy Speaker Replacement: 2 단계, 이미지 2/3 Game Boy Speaker Replacement: 2 단계, 이미지 3/3
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Speaker Replacement: 3 단계, 이미지 1/2 Game Boy Speaker Replacement: 3 단계, 이미지 2/2
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Game Boy Speaker Replacement, Outer Case: 4 단계, 이미지 1/1
    • Remove the six Triwing screws from the back of the device.
  5. Game Boy Speaker Replacement: 5 단계, 이미지 1/1
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Game Boy Speaker Replacement: 6 단계, 이미지 1/1
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Game Boy Speaker Replacement: 7 단계, 이미지 1/1
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
  8. Game Boy Speaker Replacement, Speaker: 8 단계, 이미지 1/1
    • Remove the 10 Phillips #00 screws from the motherboard.
  9. Game Boy Speaker Replacement: 9 단계, 이미지 1/2 Game Boy Speaker Replacement: 9 단계, 이미지 2/2
    • Use a plastic opening tool to gently lift the motherboard up and remove it from the front plastic case.
    • Use caution when lifting the board since the speaker is attached.
  10. Game Boy Speaker Replacement: 10 단계, 이미지 1/3 Game Boy Speaker Replacement: 10 단계, 이미지 2/3 Game Boy Speaker Replacement: 10 단계, 이미지 3/3
    • Desolder the two wires connecting the speaker to the motherboard.
    • Remove the speaker.
    • If you're new to soldering, refer to this guide for tips that will help with desoldering the speaker wires and/or soldering the new ones in place.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Andrew Tramposch
회원 가입일: 06/24/10
2,234 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010 회원
CPSU-JOHANN-R10S3G2
3 회원들
안내서 34개 작성하였습니다
댓글 2개
This is just a guide to remove the speaker not replacing it so change the title as it is misleading as people that following this will want know how to replace not remove only
Paul - 답글
As stated in the conclusion, you simply follow the steps in reverse to install your replacement speaker.
Jeff Suovanen -
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 60
30일 전: 253
전체 시간: 32,114
