주요 콘텐츠로 건너뛰기
GameSir T4 Pro Joystick Replacement
필요한 것
  1. GameSir T4 Pro Joystick Replacement, Battery: 1 단계, 이미지 1/1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Joystick Replacement: 2 단계, 이미지 1/1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Joystick Replacement: 3 단계, 이미지 1/1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Joystick Replacement: 4 단계, 이미지 1/1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Joystick Replacement, Joystick: 5 단계, 이미지 1/2 GameSir T4 Pro Joystick Replacement, Joystick: 5 단계, 이미지 2/2
    • Disconnect the rumblers from the motherboard
    • Be careful not to pull the wires while disconnecting rumbler
  6. GameSir T4 Pro Joystick Replacement: 6 단계, 이미지 1/1
    • Using the screwdriver, remove the 5 mm screws from the motherboard
  7. GameSir T4 Pro Joystick Replacement: 7 단계, 이미지 1/2 GameSir T4 Pro Joystick Replacement: 7 단계, 이미지 2/2
    • Using the wedge tool, pop the joystick out
  8. GameSir T4 Pro Joystick Replacement: 8 단계, 이미지 1/2 GameSir T4 Pro Joystick Replacement: 8 단계, 이미지 2/2
    • Make sure the square of the joystick matches the square of the pad and pop it in place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Madison Puckett
회원 가입일: 09/16/22
755 평판
안내서 5개 작성하였습니다
Western Carolina University, Team 1-4, Virtue Fall 2022 Western Carolina University, Team 1-4, Virtue Fall 2022 회원
WCU-VIRTUE-F22S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 3개
I bought ps4 joysticks for the repair, but ps4 joysticks seems larger so it's stuck
Mohamed NACERI - 답글
PlayStation4 stick is not compatible with GameSir T4 Pro. The stick for the Nintendo Switch PRO controller does not interfere, but this also requires processing for installation.
NAKIRI - 답글
It appears that you will need to remove the light diffuser(white tubular plastic sleeve) from the case to make the parts fit.
NAKIRI -
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 35
30일 전: 170
전체 시간: 3,836
