주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GameStop GS3 GameCube Controller Disassembly
필요한 것
  1. GameStop GS3 GameCube Controller Disassembly, Remove four screws on the back of the unit: 1 단계, 이미지 2개 중 1개 GameStop GS3 GameCube Controller Disassembly, Remove four screws on the back of the unit: 1 단계, 이미지 2개 중 2개
    • Turn the controller over so the back is facing upwards.
  2. GameStop GS3 GameCube Controller Disassembly: 2 단계, 이미지 3개 중 1개 GameStop GS3 GameCube Controller Disassembly: 2 단계, 이미지 3개 중 2개 GameStop GS3 GameCube Controller Disassembly: 2 단계, 이미지 3개 중 3개
    • Carefully pry open the controller. Ensure that the rumble assembly stays intact.
  3. GameStop GS3 GameCube Controller Disassembly: 3 단계, 이미지 2개 중 1개 GameStop GS3 GameCube Controller Disassembly: 3 단계, 이미지 2개 중 2개
    • Locate the two black screws attached to the rumble assembly. Remove them and separate the motor from the back casing.
  4. GameStop GS3 GameCube Controller Disassembly: 4 단계, 이미지 3개 중 1개 GameStop GS3 GameCube Controller Disassembly: 4 단계, 이미지 3개 중 2개 GameStop GS3 GameCube Controller Disassembly: 4 단계, 이미지 3개 중 3개
    • Locate the green pcb on the main assembly. Remove the silver screw on the green pcb to separate it from the controller casing.
  5. GameStop GS3 GameCube Controller Disassembly: 5 단계, 이미지 2개 중 1개 GameStop GS3 GameCube Controller Disassembly: 5 단계, 이미지 2개 중 2개
    • Locate the two silver screws on the brown pcb. Remove them and carefully pry both pcbs off of the controller casing. Ensure that the buttons on the controller casing remain in place.
  6. GameStop GS3 GameCube Controller Disassembly: 6 단계, 이미지 2개 중 1개 GameStop GS3 GameCube Controller Disassembly: 6 단계, 이미지 2개 중 2개
    • Firmly pry the plastic part of the problematic joystick off of the pcb. Take care to ensure that the pcb remains intact.
  7. GameStop GS3 GameCube Controller Disassembly: 7 단계, 이미지 1개 중 1개
    • Examine the joystick module on the pcb. Stick drift is a common problem and is usually caused by dirt and debris inside the metal casing. Use rubbing alcohol and a tissue to clean the affected area.
결론
작성자
2다른 기여자 명과 함께
Brandon
회원 가입일: 11/18/19
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 28
전체 시간: 565
