주요 콘텐츠로 건너뛰기
GameStop GS3 GameCube Controller Motherboard Replacement
필요한 것
  1. GameStop GS3 GameCube Controller Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 GameStop GS3 GameCube Controller Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Open the controller by unscrewing the screws located on the back panel
    • Separate the two halves of the controller.
  2. GameStop GS3 GameCube Controller Motherboard Replacement: 2 단계, 이미지 1/3 GameStop GS3 GameCube Controller Motherboard Replacement: 2 단계, 이미지 2/3 GameStop GS3 GameCube Controller Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove the rumble-pack by unscrewing the screws located on on either side.
    • Remove the rumble pack to fully separate the two halves of the controller
  3. GameStop GS3 GameCube Controller Motherboard Replacement: 3 단계, 이미지 1/3 GameStop GS3 GameCube Controller Motherboard Replacement: 3 단계, 이미지 2/3 GameStop GS3 GameCube Controller Motherboard Replacement: 3 단계, 이미지 3/3
    • Disconnect the motherboard from the front half of the controller by unscrewing the small screws around its perimeter.
    • The motherboard should separate and lift right out from the front half.
결론
John Harrison
회원 가입일: 10/28/16
213 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 22
전체 시간: 667
