주요 콘텐츠로 건너뛰기
GameStop GS3 GameCube Controller joysticks replacement
필요한 것
  1. GameStop GS3 GameCube Controller joysticks replacement, Joysticks: 1 단계, 이미지 2개 중 1개 GameStop GS3 GameCube Controller joysticks replacement, Joysticks: 1 단계, 이미지 2개 중 2개
    • Loosen and remove the 6 screws located on the back of the controller using your Phillips Screwdriver.
  2. GameStop GS3 GameCube Controller joysticks replacement: 2 단계, 이미지 1개 중 1개
    • Carefully pry apart the top and bottom covers.
  3. GameStop GS3 GameCube Controller joysticks replacement: 3 단계, 이미지 3개 중 1개 GameStop GS3 GameCube Controller joysticks replacement: 3 단계, 이미지 3개 중 2개 GameStop GS3 GameCube Controller joysticks replacement: 3 단계, 이미지 3개 중 3개
    • After separation, locate the rumble motor that is attached to the bottom cover of the controller.
    • Loosen and remove the 2 screws that are holding the rumble motor in place.
    • Lift and remove the rumble motor from the case.
  4. GameStop GS3 GameCube Controller joysticks replacement: 4 단계, 이미지 3개 중 1개 GameStop GS3 GameCube Controller joysticks replacement: 4 단계, 이미지 3개 중 2개 GameStop GS3 GameCube Controller joysticks replacement: 4 단계, 이미지 3개 중 3개
    • On the top cover of the controller, locate the green portion of the motherboard.
    • Loosen and remove the 1 screw in the upper left side of the green motherboard.
    • Turn the green motherboard over and attached to the motherboard will be the yellow c-stick.
    • Firmly, but carefully, pull the c-stick off, and clean around the area before reattaching or replacing the c-stick.
    • After cleaning or replacing the c-stick, reattach the green motherboard piece to the orange motherboard piece.
  5. GameStop GS3 GameCube Controller joysticks replacement: 5 단계, 이미지 3개 중 1개 GameStop GS3 GameCube Controller joysticks replacement: 5 단계, 이미지 3개 중 2개 GameStop GS3 GameCube Controller joysticks replacement: 5 단계, 이미지 3개 중 3개
    • Finally, loosen and remove the 2 screws located on the orange motherboard.
    • Pull up and remove the motherboard from the top cover. Then turn the motherboard over.
    • Locate the gray joystick that is attached to the left side of the motherboard.
    • Similarly to the yellow c-stick, firmly, but carefully, pull the gray joystick off, and clean around the area before reattaching or replacing the joystick.
결론
작성자
7다른 기여자 명과 함께
Andrew Gonsalves
회원 가입일: 10/20/16
226 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 30
전체 시간: 1,377
