주요 콘텐츠로 건너뛰기
Gameboy Advance AGS-101 Blacklight Mod
필요한 것
  1. Gameboy Advance AGS-101 Blacklight Mod, Game Boy Advance Teardown: 1 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod, Game Boy Advance Teardown: 1 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod, Game Boy Advance Teardown: 1 단계, 이미지 3/3
    • Remove the back battery cover by pinching down on the tab and pulling outward.
  2. Gameboy Advance AGS-101 Blacklight Mod: 2 단계, 이미지 1/1
    • Remove the six back panel screws using a Y1 screw driver.
  3. Gameboy Advance AGS-101 Blacklight Mod: 3 단계, 이미지 1/1
    • Remove bottom back panel screw with a Phillips #1 screw driver.
  4. Gameboy Advance AGS-101 Blacklight Mod: 4 단계, 이미지 1/1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Beware of right and left triggers, the right and left panels, and the power switch falling off as the back panel is removed.
  5. Gameboy Advance AGS-101 Blacklight Mod: 5 단계, 이미지 1/2 Gameboy Advance AGS-101 Blacklight Mod: 5 단계, 이미지 2/2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels.
    • For finicky or jammed triggers only. Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  6. Gameboy Advance AGS-101 Blacklight Mod: 6 단계, 이미지 1/2 Gameboy Advance AGS-101 Blacklight Mod: 6 단계, 이미지 2/2
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  7. Gameboy Advance AGS-101 Blacklight Mod: 7 단계, 이미지 1/1
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
    • The last screw on the right is not included on some Game Boy Advance systems.
  8. Gameboy Advance AGS-101 Blacklight Mod: 8 단계, 이미지 1/2 Gameboy Advance AGS-101 Blacklight Mod: 8 단계, 이미지 2/2
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Beware not to damage the top ribbon by pulling up gently.
  9. Gameboy Advance AGS-101 Blacklight Mod: 9 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod: 9 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod: 9 단계, 이미지 3/3
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  10. Gameboy Advance AGS-101 Blacklight Mod: 10 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod: 10 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod: 10 단계, 이미지 3/3
    • Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
    • Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
  11. Gameboy Advance AGS-101 Blacklight Mod: 11 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod: 11 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod: 11 단계, 이미지 3/3
    • Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
    • The screen and the front panel is connected by a black tape that could rip if not removed carefully.
    • You can use an iOpener or a hair dryer on the other side of the front panel in order to soften the black tape.
  12. Gameboy Advance AGS-101 Blacklight Mod: 12 단계, 이미지 1/1
    • Use the tweezers to remove the black tape if needed.
  13. Gameboy Advance AGS-101 Blacklight Mod, Cut the plastic from the shell: 13 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod, Cut the plastic from the shell: 13 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod, Cut the plastic from the shell: 13 단계, 이미지 3/3
    • Cut the plastic from the shell, aligned with red markers.
    • Use a cutter to cut the big pieces of plastic.
    • Use the cutter again to cut some plastic from the shell. This is required for the LCD to fit properly.
    • Only cut the plastic that sticks out! It's possible that the red markers are not 100% accurate.
    • First things first, there are 2 GBA models. 32 pin motherboards and 40 pin motherboards, before you order anything, make sure which model you have. The GBA's starting with a 0 is a 40 pin, if it start with a 1 it's a 32 pin. Please advise Google if you are not sure which model you have.
  14. Gameboy Advance AGS-101 Blacklight Mod, Make it flat: 14 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod, Make it flat: 14 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod, Make it flat: 14 단계, 이미지 3/3
    • Use a knife or a flathead screwdriver to flatten it. Make it as flat as possible and take all the plastic away.
    • Do this for all sides which you have cut before.
  15. Gameboy Advance AGS-101 Blacklight Mod, Fit the screen: 15 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod, Fit the screen: 15 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod, Fit the screen: 15 단계, 이미지 3/3
    • Inspect if everything is cut and if everything is flat. If it looks good, then proceed!
    • Don't worry about the front. Most of the times the front is still good, the cutting at the back side won't be visible when everything is in. But please check before you proceed.
    • Test if the screen sits flush.
    • Make sure that the screen fits good. There is not a lot of space in the shell. If you proceed anyway, you could damage the screen. Cut some more plastic if needed.
  16. Gameboy Advance AGS-101 Blacklight Mod, Attach lens: 16 단계, 이미지 1/2 Gameboy Advance AGS-101 Blacklight Mod, Attach lens: 16 단계, 이미지 2/2
    • Place a new lens in the shell.
    • It should look like the 2nd picture. It should be attached with the tape that's already on the lens. Make sure that the lens is clean and not damaged!
  17. Gameboy Advance AGS-101 Blacklight Mod, Place the screen in the shell: 17 단계, 이미지 1/2 Gameboy Advance AGS-101 Blacklight Mod, Place the screen in the shell: 17 단계, 이미지 2/2
    • Now take the plastic foil from the screen.
    • Put the screen in the shell.
    • You can attach some double sided tape in the corners of the screen to make it fit easier (make sure it's thin) it's not required. Remember not to touch the screen when the plastic security foil is removed.
  18. Gameboy Advance AGS-101 Blacklight Mod, Place the buttons: 18 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod, Place the buttons: 18 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod, Place the buttons: 18 단계, 이미지 3/3
    • Place the buttons in the shell.
    • Place the start/select rubber in the shell.
  19. Gameboy Advance AGS-101 Blacklight Mod, Place rubbers: 19 단계, 이미지 1/2 Gameboy Advance AGS-101 Blacklight Mod, Place rubbers: 19 단계, 이미지 2/2
    • Put the rubbers in.
    • You can also place the L/R buttons in already, but it won't be a problem to do this later if you want.
  20. Gameboy Advance AGS-101 Blacklight Mod, Fold the LCD cable: 20 단계, 이미지 1/2 Gameboy Advance AGS-101 Blacklight Mod, Fold the LCD cable: 20 단계, 이미지 2/2
    • Fold the LCD cable in a "Z" form. The cable is too long, this needs to be done, otherwise it won't fit.
  21. Gameboy Advance AGS-101 Blacklight Mod, Install the adapter: 21 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod, Install the adapter: 21 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod, Install the adapter: 21 단계, 이미지 3/3
    • Now it's a good time to take the adapter with you!
    • Plug the LCD cable in the ZIF socket as displayed in the 2nd picture.
    • Fold the LCD cable in the "Z" form again and place the adapter on the screen as displayed in the 3rd picture.
  22. Gameboy Advance AGS-101 Blacklight Mod, Attach tape if needed: 22 단계, 이미지 1/2 Gameboy Advance AGS-101 Blacklight Mod, Attach tape if needed: 22 단계, 이미지 2/2
    • Usually there is tape on the bracket, but if not, just place some anti-electrical tape to secure it.
    • Don't forget to fold the cable in the "Z" form.
  23. Gameboy Advance AGS-101 Blacklight Mod, Place motherboard back in: 23 단계, 이미지 1/2 Gameboy Advance AGS-101 Blacklight Mod, Place motherboard back in: 23 단계, 이미지 2/2
    • Place the motherboard in. WHEN the motherboard is at place, then proceed.
    • Put the screws back in, highlighted in red.
    • Some models have a third screw.
    • The 2nd picture shows when everything is in place with the screws in.
  24. Gameboy Advance AGS-101 Blacklight Mod, Attach ribbon cable: 24 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod, Attach ribbon cable: 24 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod, Attach ribbon cable: 24 단계, 이미지 3/3
    • Open the ZIF connector again and put the cable back in.
    • If the cable won't fit, please check your adapter and repeat step 21.
    • Close the ZIF connector with the LCD ribbon cable in. Make sure the red cable from the adapter is at it's place as shown in the 2nd picture.
    • The 3rd picture shows how it needs to be.
  25. Gameboy Advance AGS-101 Blacklight Mod, Solder the red cable: 25 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod, Solder the red cable: 25 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod, Solder the red cable: 25 단계, 이미지 3/3
    • This is the pin you need! It's the LEFT leg of DA1 !
    • Put tape on the other IC's. Just to prevent bridges and just to be sure that you have the correct pin.
    • Solder the red cable to the LEFT leg of DA1.
  26. Gameboy Advance AGS-101 Blacklight Mod, Route cable and place buttons: 26 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod, Route cable and place buttons: 26 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod, Route cable and place buttons: 26 단계, 이미지 3/3
    • Route the cable as shown in picture 1.
    • The 2nd picture shows when it's all good and finished.
    • Now place the bumpers and the L/R buttons (if not done earlier). Don't forget to place the on/off button back too!
  27. Gameboy Advance AGS-101 Blacklight Mod, Place back cover and test: 27 단계, 이미지 1/3 Gameboy Advance AGS-101 Blacklight Mod, Place back cover and test: 27 단계, 이미지 2/3 Gameboy Advance AGS-101 Blacklight Mod, Place back cover and test: 27 단계, 이미지 3/3
    • Place the backplate back and put the screws back in.
    • That's it! If everything is done it should work now. Have fun gaming!
결론
That’s it! If everything went as it should, you can play the GBA/GBC/GB games with your blacklight screen!
다른 4명이 해당 안내서를 완성하였습니다.
koppie007
회원 가입일: 08/22/13
11,662 평판
안내서 9개 작성하였습니다
Protectors Of The Game Systems Protectors Of The Game Systems 회원
Community
4 회원들
안내서 24개 작성하였습니다
댓글 11개
How would I add a way to control the brightness? is it as simple as soldering in an extra chip and wire?
Rinchanlife - 답글
Hi!
No, you can’t control the brightness with this mod. But I will try to create the IPS mod guide soon (hopefully next week)! With the IPS screen mod, you can control the brightness. But… you need to solder 3 wires. One on the TP2, and the other 2 cables for R and L buttons. You need to hold select, and press R and L to increase and decrease the brightness.
The IPS screen is a different screen with a special adapter. I’ll try to create the guide soon.
Perhaps it’s possible with another adapter for controlling the brightness on the AGS-101, but I don’t have this kind of adapter.
koppie007 -
Hi there again!
Just finished the IPS mod guide!
Link: Game Boy Advance IPS Backlight mod
If you have questions/need help, please let me know.
Good luck!!
koppie007 -
Do the ips v2 mod and the ags 101 mod require the same amount of plastic cutting?
D.J. Haynes - 답글
Hi! No. The IPS v2 mod takes less amount plastic cutting. But it’s different (for the plastic that needs a cut) regarding the AGS-101 mod.
koppie007 -
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 39
30일 전: 122
전체 시간: 12,473
