주요 콘텐츠로 건너뛰기
Garden Creations JB5629 Battery Replacement
필요한 것
  1. Garden Creations JB5629 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Take the Gardens Creations JB5629 in hand.
    • Make sure the device is turned off.
  2. Garden Creations JB5629 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the garden stake by pulling it away from the bottom plastic tube.
    • Remove the first plastic tube by pulling it away from the tube connector.
    • Remove the tube connector by pulling it away from the top plastic tube.
    • Remove the top plastic tube by pulling it away from the lamp shade.
    • Remove the lamp shade by twisting it away from the lamp head.
  3. Garden Creations JB5629 Battery Replacement: 3 단계, 이미지 1/1
    • Remove the battery cover by pushing down on the tab.
    • Replace the battery with 1 AA 1.2 V NiCd rechargeable battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anthony Smithson II
회원 가입일: 10/11/14
128 평판
안내서 1개 작성함
USF Tampa, Team 1-32, Donnelly Fall 2014 USF Tampa, Team 1-32, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G32
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 228
