주요 콘텐츠로 건너뛰기
Garmin Dash Cam 20 Camera Lens Replacement
필요한 것
  1. Garmin Dash Cam 20 Camera Lens Replacement, Internal Assembly: 1 단계, 이미지 1/2 Garmin Dash Cam 20 Camera Lens Replacement, Internal Assembly: 1 단계, 이미지 2/2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Camera Lens Replacement: 2 단계, 이미지 1/2 Garmin Dash Cam 20 Camera Lens Replacement: 2 단계, 이미지 2/2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Camera Lens Replacement: 3 단계, 이미지 1/2 Garmin Dash Cam 20 Camera Lens Replacement: 3 단계, 이미지 2/2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Camera Lens Replacement: 4 단계, 이미지 1/2 Garmin Dash Cam 20 Camera Lens Replacement: 4 단계, 이미지 2/2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Camera Lens Replacement: 5 단계, 이미지 1/3 Garmin Dash Cam 20 Camera Lens Replacement: 5 단계, 이미지 2/3 Garmin Dash Cam 20 Camera Lens Replacement: 5 단계, 이미지 3/3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Camera Lens Replacement: 6 단계, 이미지 1/3 Garmin Dash Cam 20 Camera Lens Replacement: 6 단계, 이미지 2/3 Garmin Dash Cam 20 Camera Lens Replacement: 6 단계, 이미지 3/3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Camera Lens Replacement, Motherboard Components: 7 단계, 이미지 1/2 Garmin Dash Cam 20 Camera Lens Replacement, Motherboard Components: 7 단계, 이미지 2/2
    • This step shows the use of an incorrect tool. Always use an ESD safe tool, like a nylon spudger, when working with delicate internal components.
    • Use the nylon spudger to pry the corner of the case off of the motherboard.
  8. Garmin Dash Cam 20 Camera Lens Replacement: 8 단계, 이미지 1/3 Garmin Dash Cam 20 Camera Lens Replacement: 8 단계, 이미지 2/3 Garmin Dash Cam 20 Camera Lens Replacement: 8 단계, 이미지 3/3
    • Remove the metal case off of the motherboard.
  9. Garmin Dash Cam 20 Camera Lens Replacement: 9 단계, 이미지 1/3 Garmin Dash Cam 20 Camera Lens Replacement: 9 단계, 이미지 2/3 Garmin Dash Cam 20 Camera Lens Replacement: 9 단계, 이미지 3/3
    • Remove the battery connection.
  10. Garmin Dash Cam 20 Camera Lens Replacement: 10 단계, 이미지 1/3 Garmin Dash Cam 20 Camera Lens Replacement: 10 단계, 이미지 2/3 Garmin Dash Cam 20 Camera Lens Replacement: 10 단계, 이미지 3/3
    • Remove the three 5 mm screws using the Torx T5 screwdriver.
  11. Garmin Dash Cam 20 Camera Lens Replacement: 11 단계, 이미지 1/3 Garmin Dash Cam 20 Camera Lens Replacement: 11 단계, 이미지 2/3 Garmin Dash Cam 20 Camera Lens Replacement: 11 단계, 이미지 3/3
    • Use tweezers to remove the connector on the top right of the motherboard.
  12. Garmin Dash Cam 20 Camera Lens Replacement: 12 단계, 이미지 1/3 Garmin Dash Cam 20 Camera Lens Replacement: 12 단계, 이미지 2/3 Garmin Dash Cam 20 Camera Lens Replacement: 12 단계, 이미지 3/3
    • Remove the motherboard from the case and flip to reveal SD connection.
    • Use tweezers to remove the connector next to the SD card slot.
  13. Garmin Dash Cam 20 Camera Lens Replacement: 13 단계, 이미지 1/1
    • The motherboard is now removed aside from the copper strip and its connector.
    • Disconnect from the front case and the copper strip.
  14. Garmin Dash Cam 20 Camera Lens Replacement, Camera Lens: 14 단계, 이미지 1/2 Garmin Dash Cam 20 Camera Lens Replacement, Camera Lens: 14 단계, 이미지 2/2
    • Use the Torx T5 screwdriver to remove the two 5mm screws.
    • These screws hold the camera in place. Therefore, the lens will fall into the bottom case.
  15. Garmin Dash Cam 20 Camera Lens Replacement: 15 단계, 이미지 1/1
    • The camera lens is now detached.
결론
Jesse Hillman
회원 가입일: 10/04/16
757 평판
안내서 5개 작성하였습니다
USF Tampa, Team 2-1, Cagle Fall 2016 USF Tampa, Team 2-1, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 940
