주요 콘텐츠로 건너뛰기
Garmin Dash Cam 20 Screen Replacement
필요한 것
  1. Garmin Dash Cam 20 Screen Replacement, Internal Assembly: 1 단계, 이미지 1/2 Garmin Dash Cam 20 Screen Replacement, Internal Assembly: 1 단계, 이미지 2/2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Screen Replacement: 2 단계, 이미지 1/2 Garmin Dash Cam 20 Screen Replacement: 2 단계, 이미지 2/2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Screen Replacement: 3 단계, 이미지 1/2 Garmin Dash Cam 20 Screen Replacement: 3 단계, 이미지 2/2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Screen Replacement: 4 단계, 이미지 1/2 Garmin Dash Cam 20 Screen Replacement: 4 단계, 이미지 2/2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Screen Replacement: 5 단계, 이미지 1/3 Garmin Dash Cam 20 Screen Replacement: 5 단계, 이미지 2/3 Garmin Dash Cam 20 Screen Replacement: 5 단계, 이미지 3/3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Screen Replacement: 6 단계, 이미지 1/3 Garmin Dash Cam 20 Screen Replacement: 6 단계, 이미지 2/3 Garmin Dash Cam 20 Screen Replacement: 6 단계, 이미지 3/3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Screen Replacement, Screen: 7 단계, 이미지 1/3 Garmin Dash Cam 20 Screen Replacement, Screen: 7 단계, 이미지 2/3 Garmin Dash Cam 20 Screen Replacement, Screen: 7 단계, 이미지 3/3
    • Use the Phillips screwdriver to remove the four 5mm screws.
  8. Garmin Dash Cam 20 Screen Replacement: 8 단계, 이미지 1/2 Garmin Dash Cam 20 Screen Replacement: 8 단계, 이미지 2/2
    • Use the metal spudger to remove metal plate from device. This will reveal the screen.
  9. Garmin Dash Cam 20 Screen Replacement: 9 단계, 이미지 1/3 Garmin Dash Cam 20 Screen Replacement: 9 단계, 이미지 2/3 Garmin Dash Cam 20 Screen Replacement: 9 단계, 이미지 3/3
    • Use the metal spudger to remove screen from device.
  10. Garmin Dash Cam 20 Screen Replacement: 10 단계, 이미지 1/1
    • The screen is now detached.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jesse Hillman
회원 가입일: 10/04/16
757 평판
안내서 5개 작성하였습니다
USF Tampa, Team 2-1, Cagle Fall 2016 USF Tampa, Team 2-1, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 459
