주요 콘텐츠로 건너뛰기
Garmin Dezl 760LMT Battery Replacement
필요한 것
  1. Garmin Dezl 760LMT Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Garmin Dezl 760LMT Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Battery Replacement: 2 단계, 이미지 1/3 Garmin Dezl 760LMT Battery Replacement: 2 단계, 이미지 2/3 Garmin Dezl 760LMT Battery Replacement: 2 단계, 이미지 3/3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Battery Replacement: 3 단계, 이미지 1/1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Battery Replacement, Battery: 4 단계, 이미지 1/2 Garmin Dezl 760LMT Battery Replacement, Battery: 4 단계, 이미지 2/2
    • This photo shows the use of a tool that is not ESD safe. Use a nylon spudger to complete this step.
    • Use a nylon spudger to pry the battery from the device.
    • During reassembly, place double-sided electrical tape under the battery before pressing it into its slot.
  5. Garmin Dezl 760LMT Battery Replacement: 5 단계, 이미지 1/2 Garmin Dezl 760LMT Battery Replacement: 5 단계, 이미지 2/2
    • Grasp the battery wire near the motherboard and lift upward to detach the connector.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Ryan Williams
회원 가입일: 09/28/16
763 평판
안내서 6개 작성하였습니다
USF Tampa, Team 4-2, Passmore Fall 2016 USF Tampa, Team 4-2, Passmore Fall 2016 회원
USFT-PASSMORE-F16S4G2
4 회원들
안내서 6개 작성하였습니다
댓글 2개
Completely useless as soon as you open the cover the old ribbon rips and you garmin is junk. Don’t waste your money
Pissedoff - 답글
you have to be more careful with your stuff dude..
Bealphares Voluptarius -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 23
전체 시간: 5,907
