주요 콘텐츠로 건너뛰기
Garmin Dezl 760LMT Motherboard Replacement
필요한 것
  1. Garmin Dezl 760LMT Motherboard Replacement, Back Panel: 1 단계, 이미지 1/2 Garmin Dezl 760LMT Motherboard Replacement, Back Panel: 1 단계, 이미지 2/2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Motherboard Replacement: 2 단계, 이미지 1/3 Garmin Dezl 760LMT Motherboard Replacement: 2 단계, 이미지 2/3 Garmin Dezl 760LMT Motherboard Replacement: 2 단계, 이미지 3/3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Motherboard Replacement: 3 단계, 이미지 1/1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: 4 단계, 이미지 1/2 Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: 4 단계, 이미지 2/2
    • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
  5. Garmin Dezl 760LMT Motherboard Replacement: 5 단계, 이미지 1/2 Garmin Dezl 760LMT Motherboard Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Find and lift the small grey hinge at the end of the ribbon cable.
    • When handling the motherboard, make sure to wear an anti-static wrist strap.
  6. Garmin Dezl 760LMT Motherboard Replacement, Motherboard: 6 단계, 이미지 1/2 Garmin Dezl 760LMT Motherboard Replacement, Motherboard: 6 단계, 이미지 2/2
    • Using a Torx T5 screwdriver, unscrew the six 5mm screws on the motherboard.
  7. Garmin Dezl 760LMT Motherboard Replacement: 7 단계, 이미지 1/3 Garmin Dezl 760LMT Motherboard Replacement: 7 단계, 이미지 2/3 Garmin Dezl 760LMT Motherboard Replacement: 7 단계, 이미지 3/3
    • Grasp each of the three wires near where it is attached to the motherboard. Lift them upward to detach them.
    • Lift the motherboard from the device.
결론
Ryan Williams
회원 가입일: 09/28/16
763 평판
안내서 6개 작성하였습니다
USF Tampa, Team 4-2, Passmore Fall 2016 USF Tampa, Team 4-2, Passmore Fall 2016 회원
USFT-PASSMORE-F16S4G2
4 회원들
안내서 6개 작성하였습니다
댓글 2개
i realy appreciate the video but please tell me where can i find buy the motherboard or others parts for my gps rv-760
Thank you
Pierre Delisle
Québec
Canada
Pierre Delisle - 답글
Is it possible to buy the ribbon cable from the screen to the mother board, and what’s the procedure to replace it on the display ? Thanks
Kiki B - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 2,879
