주요 콘텐츠로 건너뛰기
Garmin Dezl 770LMT Battery Replacement
필요한 것
  1. Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: 1 단계, 이미지 1/2 Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: 1 단계, 이미지 2/2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Battery Replacement: 2 단계, 이미지 1/1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Battery Replacement: 3 단계, 이미지 1/1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Battery Replacement, Battery Replacement: 4 단계, 이미지 1/3 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: 4 단계, 이미지 2/3 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: 4 단계, 이미지 3/3
    • Using a metal spudger, carefully pry the battery from the device.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
    • Before you place the battery back in, make sure to place some double-sided electrical tape to attach it to the case.
  5. Garmin Dezl 770LMT Battery Replacement: 5 단계, 이미지 1/2 Garmin Dezl 770LMT Battery Replacement: 5 단계, 이미지 2/2
    • Grasp the wire near the mother board and gently lift to detach the battery.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Francisco Rosado
회원 가입일: 10/05/16
370 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-3, Lacy Fall 2016 USF Tampa, Team 1-3, Lacy Fall 2016 회원
USFT-LACY-F16S1G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 38
전체 시간: 6,107
