주요 콘텐츠로 건너뛰기
Garmin Dezl 770LMT Screen Replacement
필요한 것
  1. Garmin Dezl 770LMT Screen Replacement, Back Panel Removal: 1 단계, 이미지 1/2 Garmin Dezl 770LMT Screen Replacement, Back Panel Removal: 1 단계, 이미지 2/2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Screen Replacement: 2 단계, 이미지 1/1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Screen Replacement: 3 단계, 이미지 1/1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Screen Replacement, Screen: 4 단계, 이미지 1/2 Garmin Dezl 770LMT Screen Replacement, Screen: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • After you've removed the back cover, you will see a copper colored ribbon connected to a grey hinge.
    • Carefully remove the hinge from the cord using a spudger and the ribbon will come out.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
    • Make sure to wear an anti-static wrist strap when handling the motherboard.
  5. Garmin Dezl 770LMT Screen Replacement: 5 단계, 이미지 1/3 Garmin Dezl 770LMT Screen Replacement: 5 단계, 이미지 2/3 Garmin Dezl 770LMT Screen Replacement: 5 단계, 이미지 3/3
    • Now you have the screen, which is enclosed by another cover. Remove the eight screws that hold it in place.
  6. Garmin Dezl 770LMT Screen Replacement: 6 단계, 이미지 1/1
    • Once the screws have been taken out, use a spudger to carefully remove the cover. With this cover removed, the screen is now completely exposed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Aleem Waris
회원 가입일: 10/10/16
146 평판
안내서 1개 작성함
USF Tampa, Team 1-3, Lacy Fall 2016 USF Tampa, Team 1-3, Lacy Fall 2016 회원
USFT-LACY-F16S1G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 2,926
