주요 콘텐츠로 건너뛰기
Garmin Dezl 770LMT Speaker Replacement
필요한 것
  1. Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: 1 단계, 이미지 1/2 Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: 1 단계, 이미지 2/2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Speaker Replacement: 2 단계, 이미지 1/1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Speaker Replacement: 3 단계, 이미지 1/1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Speaker Replacement, Speaker: 4 단계, 이미지 1/2 Garmin Dezl 770LMT Speaker Replacement, Speaker: 4 단계, 이미지 2/2
    • Using the sharp side of the spudger, scrape away the adhesive surrounding the speaker.
    • Slide the spudger beneath the speaker and pull it away from the case.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Garmin Dezl 770LMT Speaker Replacement: 5 단계, 이미지 1/2 Garmin Dezl 770LMT Speaker Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Grasp the wire connecting the motherboard and pull the wares connecting it.
    • Remember to wear an anti-static wrist strap when handling the motherboard.
결론
Francisco Rosado
회원 가입일: 10/05/16
370 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-3, Lacy Fall 2016 USF Tampa, Team 1-3, Lacy Fall 2016 회원
USFT-LACY-F16S1G3
4 회원들
안내서 5개 작성하였습니다
댓글 2개
do u know where i can get a replacement speaker
markrushforth65 - 답글
Hi where can I buy the speaker, i hardly use my deal 770 lm and speaker gave up.
Noel Borg - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 1,014
