소개
This is the guide to replacing the battery for the Garmin Drive 52 and Traffic.
필요한 것
Use a T5 Torx screwdriver to remove the four screws in the corners of the backside of the device.
If necessary, use a Jimmy or other pry tool to open the backside of the device.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Guide is great. Step by step.
At the end you could probably forgo taking out the motherboard, but better safe than sorry. Only hard part was re-attaching the screen to the zip connector again. Small space, used a flat spidger to flip the zip connector down once I had the connector strip in place.
Thank you for this guide saved me $140 on a GPS.
