소개
To replace the motherboard in your device you will need a T4 Torx screwdriver, a metal spudger, and a replacement motherboard. Be sure to have a large workspace to avoid mishandling or damaging the device components.
필요한 것
Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
거의 끝나갑니다!
결론
댓글 2개
Bonjour, ou trouver la carte mère ?
Hello, where can I find the motherboard?
i lost the screws while replacing the batterry. where do ifind the screws
