주요 콘텐츠로 건너뛰기
Garmin Drive 60LM Screen Replacement
필요한 것
  1. Garmin Drive 60LM Screen Replacement, Screen: 1 단계, 이미지 1/2 Garmin Drive 60LM Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
  2. Garmin Drive 60LM Screen Replacement: 2 단계, 이미지 1/3 Garmin Drive 60LM Screen Replacement: 2 단계, 이미지 2/3 Garmin Drive 60LM Screen Replacement: 2 단계, 이미지 3/3
    • Remove the back panel using the metal spudger tool.
    • The metal spudger tool can cause damage to internal components.
    • Flip the device over with the screen facing upward and open the device.
  3. Garmin Drive 60LM Screen Replacement: 3 단계, 이미지 1/3 Garmin Drive 60LM Screen Replacement: 3 단계, 이미지 2/3 Garmin Drive 60LM Screen Replacement: 3 단계, 이미지 3/3
    • Use a plastic spudger to flip up the white clamp holding the orange ribbon in place to the motherboard.
    • Lift the screen and orange ribbon away from the motherboard.
    • The metal spudger pictured is not ESD safe. Use a plastic spudger instead.
  4. Garmin Drive 60LM Screen Replacement: 4 단계, 이미지 1/2 Garmin Drive 60LM Screen Replacement: 4 단계, 이미지 2/2
    • Carefully unsnap the plastic border surrounding the screen.
결론
yuanhao zu
회원 가입일: 01/30/17
112 평판
안내서 1개 작성함
Baylor, Team 3-3, Whitney Spring 2017 Baylor, Team 3-3, Whitney Spring 2017 회원
BU-WHITNEY-S17S3G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 12
전체 시간: 787
